UDF : boundary condition ID
Old   June 27, 2001, 13:14
Default UDF : boundary condition ID
Flav
Every boundary condition has got an ID number.
example : boundary name : duct_inlet ID : 4
How do you get the name of the boundary condition given its ID ? In other words, what is the function that you can use in a UDF in order to get the name when you know the ID ?
Old   June 27, 2001, 15:31
Default Re: UDF : boundary condition ID
Lanre
1. Read in your mesh into FLUENT 5.
2. In the console (text interface) go to grid/modify-zones/list-zones
Old   June 28, 2001, 00:08
Greg Perkins
Another thing that's useful is to use:
thread = Lookup_Thread(domain,thread_id)
which returns the thread given a thread_id.
define extern Domain *domain in your code.
Check out the threads.h header file for further definitions....
Greg
Old   June 28, 2001, 06:07
Flav
Thanks for your help, Lanre. The problem is that the line "thread = Lookup_Thread(domain,thread_id)" provides the pointer to the thread, but not the thread name. I need to get the string which contains the name of the thread. And I can't find it, either in thread.h nor thread_tools.h.
Old   June 28, 2001, 10:52
Lanre
As far as I know, you cannot get the thread name through the UDF (read:solver) as this is something that Cortex (read:interface) associates with the thread-id. Talk to Fluent directly.
mixed inflow/outflow downstream boundary condition question peob OpenFOAM Running, Solving & CFD 3 February 3, 2017 11:54
Resolved: Changing boundary condition with UDF according to pressure outlet boundary alpemre Fluent UDF and Scheme Programming 12 February 24, 2014 11:18
UDF for inhomogenous Neumann boundary condition akhilesh Fluent UDF and Scheme Programming 3 December 24, 2012 12:14
Boundary Condition Types Using Scheme and UDF Nasir FLUENT 0 September 15, 2008 22:54
UDF for the boundary condition Sridhar FLUENT 3 July 13, 2001 20:18
