Hi all,
I want to access Fluent's calculated heat transfer co-efficient at a wall. According to p85 of my (old) udf manual this can be accessed via: h = RP_Get_Real("udf/heat-transfer-coefficient"); but I get an error from Fluent when using this function - apparently it doesn't now about this variable. Also, I would have thought that the heat transfer co-efficient is a local value - and thus not a global RP variable at all. So what does this do from example 5.6 in the udf manual?? I have found that the past variabled cid[1], cid[2] are non-zero and look like they may have the values of the heat transfer co-efficient as computed by Fluent. Can anybody confirm this?? Greg |
Heat transfer BC at wall- why need wall thickness? | Julie | FLUENT | 7 | February 3, 2012 21:41 |
UDF for wall slipping | HFLUENT | Fluent UDF and Scheme Programming | 0 | April 27, 2011 12:03 |
natural convection | mehrdadeng | CFX | 10 | February 25, 2011 05:25 |
heat flow UDF on coupled surface (wall-shadow wall) | Friedmann | Fluent UDF and Scheme Programming | 0 | August 5, 2010 10:25 |
No results for solid domain | Gary Holland | CFX | 10 | March 13, 2009 03:30 |
