What's wrong with my UDF?
Old   June 22, 2001, 12:36
Default What's wrong with my UDF?
olivia
Hi everybody:
This article is a little too long. I would like to thank you first if you are so insterested to go throuth it.
I want to solve heat and moisture transfer analysis.
This problem is the heat tranfer in conjunction with moisture transfer. This is a 3-D problem. The solution domain is cube of dense bale.
The governing equation is following for 1-D:
dM / dt = Dm * d^2 m / dx^2
dT / dt = alpha * d^2 T / dx^2 + 1 / Cp * dM / dt * Lg
M : is the moisture
t : time
Dm : moisture diffusivity
T : temperature
alpha = thermal diffusivity
Cp : specific heat at constant pressure
Lg = L * (1 + 8.31 * exp(-0.436 * m)
L = 2440
The boundary conditions are
at surface
M = (Mi - Me)* exp(-Km * t) + Me
Km : moisture sorption rate, Km = 1.83e-4
T = 45 deg C
The initial condition
T = 18 deg C
M = 0.85 both T and M is uniform.
I want to solve this problem with Fluent v.5.5. I add an user-scalar transport equation to solve the moisture. Then determine the time derivative of moisture and substitute it into the energy equation as the source term. I employed the UDF function to do my
job. However I encountered some problem. The compilation of UDF is ok, but something is wrong in excution. The error message is as follow :
Error:
FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
Error Object: ()
I woundered that there is some bugs in my UDF codes.
Maybe it is due to wrong type of passed argument or incorrect usages of some subroutine. I hope that somebody help me to debug my codes. My code is as follow :
#include "udf.h"
#define rho 1000
#define l 2440.0
#define mi 100.0
#define me 50.0
#define km 1.83e-4
#define el 1.0
DEFINE_UDS_UNSTEADY(uds_unsteady, cell, thread, i, apu, su)
float time_step, vol, phi_old, phi_curr;
time_step= RP_Get_Real("physical-time-step");
vol = C_VOLUME(cell,thread);
phi_old = C_STORAGE_R(cell,thread,SV_UDSI_M1(i));
phi_curr = C_UDSI(cell,thread,i);
*apu = -rho*vol*phi_curr/time_step; /*central coefficient part*/
*su = rho*vol*phi_old/time_step; /*source term part*/
DEFINE_SOURCE(usr_ensource, cell, thread, ds, eqn)
real source;
float lg,A,phi_curr,phi_old,time_diff,vol,time_step;
phi_old = C_STORAGE_R(cell,thread,SV_UDSI_M1(0));
phi_curr = C_UDSI(cell,thread,0);
time_diff = (phi_curr - phi_old) / time_step;
/* uscl = C_UDSI(cell,thread,0); */
lg = el * ( 1.0 + 8.31 * exp(-1.0 * 0.436 * phi_curr) );
A=1.0/0.5*lg;
source = A * time_diff * vol * rho;
ds[eqn] = 0.0;
return source;
DEFINE_PROFILE(usr_bndry, thread, position)
face_t f;
begin_f_loop(f,thread);
real flow_time = RP_Get_Real("flow-time");
F_PROFILE(f,thread,position) = (mi - me) * exp( - 1.0 * km * flow_time) + me;
end_f_loop(f,thread);
Thanks again
Old   June 23, 2001, 18:06
Default Re: What's wrong with my UDF?
John C. Chien
(1). Why not try to write a finite-difference code for this set of parabolic differential equations. (2). Most numerical method books should give you some schemes to start with. (a good reference book is: Applied Numerical Methods by Carnaham,Luther, Wilkes)
parse error while interpreting udf Kristin Fluent UDF and Scheme Programming 3 March 15, 2012 07:43
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
I need UDF help. S.Whitney FLUENT 0 October 15, 2007 12:29
what's wrong with the UDF major FLUENT 6 March 3, 2005 07:39
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 05:03
