UDF reading species data of pdf simulations
Old   June 20, 2001, 18:15
Default UDF reading species data of pdf simulations
Jamiro
Hi CFD friends!
I'm implementing a UDF for NOx calculations on a pdf solution: I'm using the built-in DEFINE_SOURCE function to add a customized reaction rate to NO transport equation. To do this my UDF must read the values of some mass fraction species (variables C_YI(c,t,i)), already calculated in the main simulation. But running it, I don't succeed in performing one iteration at all because an error "SEGMENTATION VIOLATION..." appears. I guess it is because in pdf calculations only 'fmean' and 'fvar' are variable solutions, while species mass fractions are calculated in post-processing by means of look-up tables. In fact, running the same UDF on a finite-chemistry solution no problem was encountered.
Anyone may clarify that and purpose a solution for pdf species data to be read (or pointed) by this kind of UDF for NOx?
I'm thanking you a lot for any suggestion.
Jamiro
UDF (write a data file) problem lichun Dong FLUENT 2 July 29, 2005 12:39
Retrieving species in UDF Fernando FLUENT 0 September 3, 2004 09:22
UDF and PDF species mass fractions Ale FLUENT 0 July 18, 2003 10:04
Reading data file MON FLUENT 4 September 20, 2002 15:25
Accessing solution data in UDF Ale FLUENT 1 June 12, 2002 01:25
