inlet and outlet boundary
Old   May 10, 2001, 04:45
Default inlet and outlet boundary
you
I am calculating a flow field with backward velocity at the inlet and outlet boundaries. Please tell me how to set the inlet and outlet boundary conditions for this flow. Thank you very much !
With best regards, You
Old   May 10, 2001, 15:21
Default Re: inlet and outlet boundary
John C. Chien
(1). As a general rule, you should set your inlet and outlet conditions such that it will simulate the test conditions.(as if you are running the test in the laboratory) (2). Because of the nature of the iterative algorithm used, it is possible to have reverse flow during the iteration process. There is not much you can do there,because it is part of the method used in the code. (3). But if you provide a better initial flow field, then it should improve the situation.
Old   May 10, 2001, 18:10
you
Hi Dr. Chien,
Thank you very much for your help.
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 07:18
Please help with flow around car modelling! Tudor Miron CFX 17 March 19, 2004 20:23
