Distribution of particles around porous media
Old   April 30, 2001, 15:22
Default Distribution of particles around porous media
CHUBBY
hi everyone ,
I am involved with a project realted to random particle (mixed with air) distribution around a porous media. I am supposed to study the accumulation and distribution of these particles around the porous media, the turbulence created with these particles in the air around the porous media .The air : particle volume ratio is 1:0.005. I have a very little knowledge about Discrete random walk.(DRW) . I would be immensely pleased if someone could through light on DRW applicable to my prtoject. Any other suggestions are also welcome. Thanking u Chubby
Old   April 30, 2001, 17:26
Default Re: Distribution of particles around porous media
Newbie
You'll have Brownian effect if you have very small particles, about 1 micra in liquid, I don't know in gas but I think it will be the same. Then you can set up a porous media in an UDF as explained in the manual and add the DPT method.The problem you'll have is that the particles won't have direct interaction with the porous media as it is only conceptually built-in.
Good Luck
Multiphase Porous Media Flow - Convergence Issues VT_Bromley FLUENT 8 May 30, 2024 03:59
Porous media setup issues in Fluent Bernard Van FLUENT 29 January 26, 2017 05:09
How to model granular flow through porous media Axius FLUENT 2 August 7, 2014 11:34
Temperature Distribution in porous media Munir Ahmed Khan FLUENT 0 August 2, 2008 10:02
porous media: Fluent or Star-CD? Igor Main CFD Forum 0 December 5, 2002 16:16
