Limitations of the parallel versions of FLUENT
Old   April 26, 2001, 22:18
Default Limitations of the parallel versions of FLUENT
Danial.H
is the dedicated parallel versions of FLUENT is different from the parallel network version on Windows NT? if they are different:
which one can run on a windows NT network of two computers, one of them is dual processor PIII667 and the other is single processor P233 ? will the performance be affected by using different processors (different speed)? and if they aren't different:
can this parallel version of fluent run on the previously specified WindowNT network OR on a windows NT multi processor Machine?
Old   April 27, 2001, 10:15
Default Re: Limitations of the parallel versions of FLUENT
Lanre
Fluent parallel can run on both multiprocessor NT's or distributed NT clusters. the performance of any parallel computing system is greatly affected by the weakest link. It's probably time to get rid of the old 233MHz machine anyway and upgrade so that all processors are of equivalent speed.
Parallel Error in ANSYS FLUENT 12 zeusxx FLUENT 25 July 17, 2015 05:40
Urgent; parallel processing in fluent 12 Mansureh FLUENT 4 September 25, 2012 12:12
Fluent Parallel Error Will Humber FLUENT 2 April 3, 2008 15:15
Fluent parallel poovanna FLUENT 0 March 24, 2007 00:22
FLUENT parallel run Sampath FLUENT 6 November 24, 2004 10:52
