emulsion filtration
Old   April 26, 2001, 16:17
Default emulsion filtration
Fu
I am investigating the mechanism of emulsion filtration. Here is the problems I met: 1) since the description in pore scale (pore size of membrane is around 2 micron) is needed, the porous model in Fluent is not useful. 2) The emulsion has an oil concentration in the bulk fluid, but near the membrnae surface, the concentration of oil droplet is fairly high (30%--60%) and interaction between droplet is significant (also,rupture and coalascence may occur).So DPM in Fluent is not suitable. 3) is there any commercial software can deal with this problem?
Thanks a lot.
Membrane filtration simulation problem Jiessie.liu Main CFD Forum 1 June 1, 2018 05:09
emulsion devalpandya ANSYS 0 February 25, 2011 16:18
Help on using Fluent CFD to compute emulsion flow. Kes FLUENT 0 May 5, 2008 02:19
Water Filtration System omar FLUENT 2 February 23, 2005 11:36
Any experience in Filtration Problems? Sandeep Abhyankar FLUENT 0 December 16, 1999 14:54
