GAMBIT grid export problem
Old   April 20, 2001, 23:19
Default GAMBIT grid export problem
Alex Yang
I am a new user of Fluent. I meshed a cylinder with 3D elements by GAMBIT and exported it. But when I imported the grids into Fluent and checked it, I found I can't find correct boundary zones, thus I don't know how to add boundary conditions. Anyone can help me? Thanks a lot.
Old   April 22, 2001, 03:46
Default Re: GAMBIT grid export problem
yulia
You should define your boundary zones in Gambit (first define the solver (Fluent 5 I presume). Then you can define actual boundary conditions in Fluent.
Yulia.
Old   April 23, 2001, 05:08
Harry Qiu
Hi, In gambit after defining the solver as Fluent 5 and meshing the computed domain, you should define your boundary zones with "zone command button" . Then you can export mesh file and read into fluent 5 and then define actual boundary conditions in Fluent. I hope it can give you a hand. Harry.
Gambit Axisymmetric Neutral File Problem SandyS OpenFOAM 4 March 25, 2014 08:08
mesh missing after export in gambit morteza08 ANSYS Meshing & Geometry 1 July 26, 2010 02:10
mesh missing after export in gambit morteza08 Main CFD Forum 0 July 23, 2010 03:19
Problem importing solidworks to gambit holyo ANSYS Meshing & Geometry 3 April 16, 2010 06:16
Problem starting Gambit ViHAR MALViYA FLUENT 0 November 10, 2006 11:26
