input only by text commands
Old   April 12, 2001, 15:13
Default input only by text commands
Peter Kolb
Hi everybody,
unfortunately we must use Fluent in batch mode. For this reason I can not work with GUI but with the input of the special commands in the display window (I write this serie of commands in an input file). Now I want the information of a surface integral (GUI: Report --> Surface Integrals --> Compute: Area-Weighted-Average ; Field Variable: Phases ; Surfaces: outlet) How can I get this information only by using text commands?
write report and after that ? surface-avg ? surface-int?
Thanks for help Peter
Old   April 17, 2001, 08:02
Default Re: input only by text commands
Volker Pawlik
report
surface
surface-avg
id1
id2
"field-variable"
This jou-file should help. id1 and id2 represents the surface-id which you can be find in the "surface manage" panel or under /display/surface/list-surface.
() stops the scheme command.
Alternately (id1 id2) should work too.
Volker
variable time stepping text commands moe FLUENT 0 September 2, 2009 12:19
Using text commands in FLUENT shankara.2 FLUENT 2 July 20, 2009 15:18
DPM Particle tracks summary text input Rajesh Gutti FLUENT 1 October 17, 2008 03:29
Text input commands to add data points Kathryn FLUENT 0 November 5, 2007 18:38
Execute Commands from input file Greg Z FLUENT 1 May 24, 2006 17:56
