How to specify Hardcopy to save
Old   April 10, 2001, 19:30
Default How to specify Hardcopy to save
HGG
Dear all, How to specify a paricular window graphic to save a hardcopy, there are three graphic window,1.display contour,2.display resodual,3. display one surface monitor,I want to save surface monitor graphic,but each time the velocity contour graphice was saved,how to specify desired window to save graphic as a hardcopy,many thainks in advance.
Old   April 11, 2001, 06:31
Default Re: How to specify Hardcopy to save
ling
Press you mouse in the window you want to saved,and then hardcopy, it will be ok.
Old   April 13, 2001, 17:01
Xiao Hu
Go to Display--> Option and activate the desired window there.
How can I save a mesh file in ANSYS Workbench V12 for standalone mode CFX-Pre? fkonias ANSYS Meshing & Geometry 22 March 18, 2017 10:38
How to save images of contour plots during parallel job Neil11 FLUENT 5 September 23, 2010 20:06
how to save the hardcopy in every time step yubaibai88 FLUENT 12 May 27, 2010 10:28
How to save 2-D data in contour plot mssound FLUENT 0 February 15, 2010 15:01
How to save only a slice,not the whole data? leon Siemens 3 August 25, 2005 11:55
