April 5, 2001, 22:32 |
How define K and epslon for INLET?
Dear everyone:
How to define K and epslon for INLET? thank you Sincerely, Harry. |
April 6, 2001, 12:13 |
Re: How define K and epslon for INLET?
why you need to do that? the K & epslon is for the flow inside(interor) onley so you dont have to define K and epslon for the inlet onley .the K & epslon is one kind of modeling the turbelnt flow and should be fixed for all the fluid domain
April 6, 2001, 12:30 |
You need to specify inlet turbulence quantities. They are an essential part of defining a turbulent flow problem.
k=1.5(U I)^2 U=local velocity magnitude I=turbulence intensity eps=[(Cmu^.75)*(k^1.5)] / l Cmu=0.09 (for standard k-eps model) k=turbulent kinetic energy l=turbulent length scale You can specify other inlet turbulence parameters in Fluent such as turbuelnt intensity & viscosity ratio. You are not limited to specifying k&eps. Chinor |
April 6, 2001, 12:36 |
thank you Chinor for this useful information can you forward to me the refrences that you get your equations from so i can read all the realted articels thanks again
April 13, 2001, 17:16 |
k and e are rarely used directly. Instead, you have three more choices. If you have an internal flow, turbulence intensity and hydraulic diameter is your best choice. If you are soling an external flow, turbulence intesity and turbulence viscosity ratio is your best choice.
Epslon error. | Samir | Main CFD Forum | 0 | April 12, 2005 09:23 |
