how to obtain permeability factor of porous media? |
March 28, 2001, 01:30 |
I am modeling a laminar gas flow through porous media. The fluent manual said that the porous media may reduces to Darcy's law, and I do not have to define the inertial resistance factor, C_2. However, I still do not know how to define the permeability, alph.
March 28, 2001, 10:04 |
Re: how to obtain permeability factor of porous me
Sean:
Alpha is the inverse of the permeability. To obtain an estimation of the permeability tensor, you need to know the porosity of the porous media. Also, the unit vector direction is important. Mel |
March 28, 2001, 10:16 |
Mel: You are so kind to give me an answer. Do you mean that I can deduce the viscous resistance coefficient, which is the inverse of the permeability, from the porosity of the porous media in a vector direction? Fluent manual told me that porosity is the volume fraction of fluid within the porous region.
sean |
March 28, 2001, 13:05 |
Sean:
The permeability is a tensor, you need a magnitude and two direction to specify the permeability. The permeability is a function of the porosity, i.e. pore volume fraction. Mel |
October 25, 2011, 01:25 |
porous media
vittal
Rep Power: 14 |
Can any one help me out how to calculate permeability and C2 if i know porosity.I am unable to know how the unit directions are mentioned.
Please help me in this process. |
Porous media setup issues in Fluent | Bernard Van | FLUENT | 29 | January 26, 2017 04:09 |
How to model granular flow through porous media | Axius | FLUENT | 2 | August 7, 2014 10:34 |
Permeability of porous media | Alex | FLUENT | 0 | April 25, 2007 02:00 |
Permeability to porous media parameters | Night | FLUENT | 2 | June 28, 2006 02:19 |
porous media: Fluent or Star-CD? | Igor | Main CFD Forum | 0 | December 5, 2002 15:16 |
