boundary condition of a wall between two solids |
March 23, 2001, 09:33 |
I am confused when I define boundary conditions of a wall between two different solids. The thermal conditions listed are heat flux, temperature, convection, radition, and mixed. Since I do not know the heat flux through the wall, and the temperature is not fixed, the first two typies are not applicable. The later three typies are not suitable for two solids, I think.
Somebody help me. |
March 26, 2001, 08:32 |
Re: boundary condition of a wall between two solid
Hi, Are you Chinese, I'm too. I think your problem can be solved in the GAMBIT. When you create the geometry model, create only one edge as the common wall between two solid zones(it's very important). When you define the thermal condition of that "two-side" wall, the thermal condition type is specified as "coupled" by default. Actually, you need input nothing. I hope it can give a hand. Sincerely, Harry Qiu.
March 26, 2001, 09:18 |
You are right. I really appreciate your help.
Yes, I am Chinese. |
isothermal wall boundary condition | Neil | Main CFD Forum | 3 | November 9, 2015 03:34 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
External Radiation Boundary Condition for Grid Interface | CFD XUE | FLUENT | 0 | July 9, 2010 03:53 |
how to set up a wall boundary condition according to calculated wall shear stress? | gameoverli | OpenFOAM Pre-Processing | 1 | May 21, 2009 09:28 |
Variable temperature wall boundary condition | Virginie | FLUENT | 2 | October 2, 2007 10:23 |
