which combustion model can be in supersonic field
Old   March 9, 2001, 23:13
Default which combustion model can be in supersonic field
cfdfans
Hello I want to use fluent5 to anlyse the combustion in supersonic field,but I don't konw which combustion model work well in supersonic.By the manual,the PDF model can'n used in compressbile fluid.I use finite rate(eddy dissipation)model and thane-air species, but the result is not correct,there is no product in the field.
How can I do ? Any help is greatly appreciated.
hel (turbulent viscosity ratio limited) for supersonic combustion problem omar.2002bh FLUENT 2 September 5, 2012 12:04
Combustion in ICE - Weller model roadracer Siemens 1 July 22, 2009 05:54
Weller combustion model roadracer Siemens 0 October 6, 2003 06:07
Combustion model in Diesel Engines roadracer Siemens 1 May 13, 2003 11:05
combustion model Hennie van der Westhuizen Siemens 7 February 27, 2002 03:10
