GAMBIT merge and export mesh
Old   March 7, 2001, 23:55
Default GAMBIT merge and export mesh
sean
In gambit,select solver as Fluent5. file name: test.
After split a volume into two parts, mesh each of them seperatively, then merge them(real), export mesh,
the trn file says: to GAMBIT Neutral file\tfilter fe2ram -surface -tGAMBIT >test.msh
However, as I read the mesh into FLUENT5.48(read-case), it says Error: FLUENT received fatal signal (ACCESS_VIOLATION)
I once exported the mesh before merging the two volumes,and FLUENT worked well.
Guys, help!
Old   March 8, 2001, 08:11
Default Re: GAMBIT merge and export mesh
Flav
Before merging the 2 meshed volumes, have a look at the mesh : use the Examine Mesh panel (right-hand side, at the bottom of your screen). In the "Range" menu, you can see that there is a certain number of 3D cells. You can also display a cut to see the cells.
Now if you merge the 2 volumes, examining the mesh will tell you that there is no 3D cell any more. Only faces.
That is why Fluent does not appreciate to read a 3D mesh, which is only a skin mesh (2D cells).
Old   March 8, 2001, 08:18
sean
Then what shall I do?
Old   March 8, 2001, 08:33
Flav
Start meshing only when your geometry modifications are done.
Old   March 8, 2001, 08:50
sean
Flav, What shall I modify the geometry?
question on generating sliding mesh in Gambit multiphase-flow FLUENT 4 February 21, 2012 01:36
Mesh 2 bodies in 2 different programs Doginal ANSYS Meshing & Geometry 4 September 21, 2011 13:16
Export 2D mesh from ICEM to Fluent BuilttoSpill ANSYS Meshing & Geometry 4 August 28, 2010 09:16
importing Icem mesh into Gambit srinivas FLUENT 4 December 12, 2008 05:06
Gambit error in exporting mesh in 3D modeling Mazyar FLUENT 5 March 31, 2004 11:50
