March 5, 2001, 05:28 |
DRAG CALCULATIONS
Can anyone give me an idea of how Fluent goes about calculating drag (CD) values.
Is it possible in Fluent so look at the contributions of skin friction and pressure drag to overall drag, to see where my error is comming from? Regards |
March 11, 2001, 05:32 |
Re: DRAG CALCULATIONS
Fluent calculated the Cd values base on the following formula: Cd=Fx/(0.5*density of fluid*mean velocity^2*projected area) Fx was integrated by Fluent but the density of fluid, mean velocity and projected area has to be entered by your own in the reference menu. these values would not affect the model but just the force coefficients (Cd, Cl and Cm) reported by the software. For Fx, it was contributed by pressure force and skin friction, you could see the value of Fx or force and moment at any specified direction or location by in the report menu. Force contribted by Pressure and friction would be listed separately. Desmond |
March 16, 2001, 13:44 |
Is there a provision to monitor the contributions (pressure and friction) separately?
Thanks |
March 17, 2001, 01:25 |
I think you could not "monitor" it by ploting the pressure and friction drag separately against no. of iteration during iteration, but what you could do is to stop by several iteration and stop to record the change of these 2 quantity manually.
Pressure drag, friction drag and total drag? | Cheng | CFX | 9 | January 26, 2024 14:46 |
Drag Calculations | davey | OpenFOAM | 0 | September 21, 2009 12:15 |
drag calculations | Alex | Phoenics | 9 | July 18, 2004 21:07 |
Drag and Lift Calculations | Sam | CFX | 4 | June 30, 2003 16:29 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 13:19 |
