February 25, 2001, 08:10 |
define faces within GAMBIT in imported mesh
Hi there,
I am trying to set boundary conditions on a 3D mesh of a gas turbine combustion chamber imported into GAMBIT. The mesh was exported from CFD-ACE, and obviously information concerning faces created for several inlets are lost, therefore only faces defining the outline can be selected. My question is whether faces such as circles for inlets can be redefined from existing cells or additionally embedded without remeshing the whole volume. Are there possibilities within GAMBIT or is there a solution when using any other meshing tool? Thank you for your advice! Yours, Elmar |
[ICEM] Extrude Mesh without internal faces | TWaung | ANSYS Meshing & Geometry | 3 | May 29, 2019 06:18 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 22:11 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 20:43 |
choosing faces in CFX with imported WB mesh | mactech001 | CFX | 1 | December 7, 2009 03:30 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 13:24 |
