February 22, 2001, 14:52 |
residual monitor
Dear all:
I am new user of Fluent. I'd like to know the meanings of of residual monitor when I calculate the transient problem use explict solver. Thanks |
February 26, 2001, 13:34 |
Re: residual monitor
Checking the residuals values when performing a transcient calculation is very important, since it tells you whether or not each time step is correctly solved. In fact, you have to set the right number of iterations per time step, in order to reach a good level of convergence for every time step.
I reckon that you should also monitor one or several physical parameters, in order to be sure that the solution is "stabilized". Residuals value is one criteria, but if the physical properties of the flow don't have enough iterations to reach THE solution, what you get just doesn't make sense. |
transsonic nozzle with rhoSimpleFoam | Unseen | OpenFOAM Running, Solving & CFD | 8 | July 1, 2022 07:54 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 12:08 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 16:33 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 06:24 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 12:16 |
