Normal distance from a particle to a surface
Old   February 16, 2001, 11:25
Default Normal distance from a particle to a surface
Newbie
I need to calculate the distance of a particle moving in a flow field normal to a sphere. In Gambit I defined the sphere in the center of the domain ( coordinates 0,0) so the distance could be easily calculated. I have some extrange results and I have some facts that tell me that when the grid is interpreted in fluent 5.5, the coordinates are changed. I'm really not sure, and I would like to hear of someone's experience. Also if somebody has a better Idea on how it can be done independently from the grid.
Thanks a lot
Arturo
Old   February 26, 2001, 13:44
Default Re: Normal distance from a particle to a surface
Flav
I don't think the coordinates of your grid are changed when you read it into Fluent.
You can check the domain dimensions with Grid/Scale. Should there be any kind of problem with dimensions, you would see it immediately.
To do it independently from the grid, maybe you should use a Define/CustomFieldFunction to set up some coordinates that suits your problem.
Particle Surface Reaction NunoLFC FLUENT 0 June 22, 2011 11:52
[ICEM] Automatic mesh generation script surface intersection problem stuart23 ANSYS Meshing & Geometry 0 May 13, 2011 02:10
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 02:29
particle surface reaction ardeshiri FLUENT 0 September 14, 2008 06:23
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
