Radial and tangential velocity
Old   February 15, 2001, 10:41
Default Radial and tangential velocity
Antonio Mileo
Dear all, it is not clear to me what is meant in Fluent by "radial" and "tangential" velocity .Specifically, in my problem of flow around a cyilinder, radial velocity on cylinder surface ("shadow") is different from zero and of the same order of tangential velocity. Can anybody also explain me better what is a "shadow" and why do I have these high velocities there? Thanks for your attention
Old   February 15, 2001, 17:42
Default Re: Radial and tangential velocity
John C. Chien
(1). If you are using someone's code, you should contact the vendor of the code. (2). It is their responsibility to tell you how the code works, especially how they handle the surface boundary conditions.
Old   February 16, 2001, 02:41
Jurek
radial/tangential is defined by the "coordinate-system" you set in define/boundary-conditions/fluid. You find there a "rotation-axis".
shadow appears, if you define a wall with thickness=0. Then you need a wall on the one side and one wall to the other side (and this one is the shadow-wall).
The velocities are extrapolated to the walls. Use x/y/z-velocity for velocities on the walls (or functions from those). They give exact "0".walls.
Plotting Radial Velocity and Tangential Velocity in CFD Post ashtonJ CFX 5 July 13, 2015 03:49
Radial and Tangential Velocity boundary conditions N. A. OpenFOAM 4 September 2, 2011 08:21
how to extract the components of radial and tangential velocities renyun0511 OpenFOAM Running, Solving & CFD 0 April 8, 2011 08:15
Cylindrical coordinate system - tangential velocity alessio.nz OpenFOAM 2 December 7, 2010 06:07
Cyclone Tangential Velocity ... Abdul FLUENT 2 August 13, 2008 01:07
