Gambit mesh & Negative Volumes
Old   February 9, 2001, 08:51
Default Gambit mesh & Negative Volumes
Ashutosh
Hi Fluent User's I am modelling a complex geometry and meshing it by subdividing it. When I mesh the volumes with coarse size and import the mesh into Fluent, it has negative volumes. What may be the cause of this problem? In Gambit I am checking the volume but it doesn't show any negative volume. Also in Fluent I try to use command : grid>grid-modify>face-handedness, then also the problem remains and grid check fails because of negative volume.The mesh is tetrahedron and the skew angle for coarse mesh case for few ( 10-20) cells is around 0.95.When I refine some volumes the problem disappears. But the no. of cells are more by 20%. What may be the cause and possible remedy for that? Thanks for any suggestions. Ashutosh
Old   February 11, 2001, 13:34
Default Re: Gambit mesh & Negative Volumes
John C. Chien
(1). Try to solve a simple geometry problem first, to see whether you still have the negative volume problem. (2). If the problem is still there, call your support engineer. (3). For your complex geometry problem, first ask your support engineer to see whether it can be handled by the code or not. (4). It is not possible to answer your question because I don't know whether a general code can handle a complex geometry of yours. "EACH GEOMETRY AND MESH IS A SPECIFIC CASE". (5). It is likely that the algorithm inside the black box(the code) does not like your complex geometry and your processes to create a mesh. (A company using a commercial code without experienced engineer is likely to die many times.)
Old   February 12, 2001, 14:10
Kai Kang
1. sub-divide more
2. you can examine negative volumes (if any) in Gambit by shading the mesh. Becuase the surface normal of the negative volume would be different from the other good ones, there is a slightly difference in shading...
3. gambit check mesh (topology and geometry) works,too.
Old   February 12, 2001, 23:37
Ashutosh
Thanks Kang,
I would like to visualize the negative volumes if any in Gambit itself. Why the volume check in Gambit doesn't show negative volumes? It should work the same way we check skew angle, aspect ratio etc.If we put lower limit as negative then it should show that there are some cells ( if any) with negative volumes. Your suggeation of subdividing volumes further is well considered.
regards Ashutosh
Old   February 20, 2001, 11:37
Flav
I've just had a look at your .dbs file. You should try a geometry simplification for the meshing, by means of the virtual tool. Merge some of the faces, I mean the ones whose nodes are very close to each other, but not connected. That is the reason why you get some cells with skewness>0.95. The tetra cells generated in places where vertices are very close are flat, and therefore of poor quality.
Old   February 21, 2001, 01:59
Ashutosh
Thanks Flav, I also got similar skewness value over which the chances of getting negative volume are more.I may have to merge some nodes to get lower skewness, or use more small volumes. Even if I am successful in creating mesh with high skewness without negative volume, the convergence time would increase. So I may have to optimize between the solution time and no. of cells. Ashutosh
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 07:21
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
Problems with gambit mesh lions85 FLUENT 2 August 28, 2009 20:05
Alternate method to subtracting volumes? Daniel Lee FLUENT 2 July 25, 2005 09:58
