January 7, 2001, 12:09 |
help: data format - post processing
I am working on a transient problem and have output about 1000 data files. I would like to write a stand alone C or Fortan code to read in all the data files, compute some parameters from each data file, and then save the computed parameters as a funtion of time to a file. Does anyone know the data format (binary) of Fluent or can anyone suggest where I can find it? Thanks! Pei-Ying Hsieh |
January 10, 2001, 14:25 |
Re: help: data format - post processing
Hi, Fluent support engineer used to send me Fluent's data file as ASCII files. So the data format may be ASCII. I am not absolutely sure about it...just want to share my experience.
Good luck Billy |
Best format for simulation data? | cbisw | Main CFD Forum | 9 | May 30, 2011 03:38 |
post processing using fluent data | Ramesh.K | FLUENT | 3 | October 29, 2008 12:20 |
post process to get an arbitrary face data | oniboy | Siemens | 2 | February 28, 2008 23:12 |
Can you post a blade data points file example??? | Nicola | Fidelity CFD | 0 | September 21, 2007 12:38 |
post processing in CFD | MANISH BHARGAVA | Main CFD Forum | 0 | October 17, 1998 21:51 |
