Bundle representation using Porous media
Old   December 12, 2000, 05:50
Default Bundle representation using Porous media
Hooky
I have tried to simulate a bundle of tubes by using the porous media option. First I did a simple 2d case of a periodic part of the bundle as represented in the handbook (tutorial 3). I did several simulation for a range of inlet velocities between low velocity and maximum velocity (compared with the real geometry). From the data I am able to plot the relation between the free inlet velocity and the pressure drop. Using the Ergun equation it is possible to determine c2 and alpha (by using a parabolic trendline). The order of magnitude seems correct for both parameters but after simulation in the final geometry c2 is under extimated. Do you have any previous experience in this field and could you advice me on the procedure to follow?
Thank you for your cooperation.
Hooky
Old   December 12, 2000, 22:48
Default Re: Bundle representation using Porous media
Greg Perkins
The Ergun equation may not be a good/the best equation to use to represent a bundle of tubes - since the equation is developed assuming a packed bed of spheres. Maybe consider another equation for representing the solid-fluid drag intereaction.
Greg
Old   December 13, 2000, 00:57
Dan Williams
Wow that sounds pretty convoluted. Couldn't you just define an source term for the momentum equation which has different resistance depending upon the coordinate direction. You can do this quite easily in CFX-5.
Old   December 13, 2000, 01:01
Greg Perkins
Its easy in Fluent too - I suppose the point is what form this source term should take!
Old   December 13, 2000, 04:55
Hooky
There are empirical relations to determine the pressure drop in a bundle of tubes but it is not possible to separate the inertial resistance from the viscous resistance. It is relatively easy to calculate the inertial resistance for a bundle of tubes and in most of the case it is pretty accurate. However I would like to have an idea of the viscous resistance effect on the flow. Now, how could this coefficient be evaluated?
Thanks
Multiphase Porous Media Flow - Convergence Issues VT_Bromley FLUENT 8 May 30, 2024 03:59
Porous media setup issues in Fluent Bernard Van FLUENT 29 January 26, 2017 05:09
How to model granular flow through porous media Axius FLUENT 2 August 7, 2014 11:34
Tube bundle simulation using porous media Jitendra Main CFD Forum 2 April 13, 2004 08:57
porous media: Fluent or Star-CD? Igor Main CFD Forum 0 December 5, 2002 16:16
