C++ Compiler for UDF
Old   November 29, 2000, 08:04
Default C++ Compiler for UDF
Dmitriy Makarov
Dear all,
I need to compile my UDF. Fluent's Win NT FAQ page strictly advises Microsoft Visual C++ 6.0 compiler as the only choice. Is it really the only way to do it?
I have Borland C/C++ 5.01 GNU, which contains Microsoft NMAKE version 1.60.5270. It seems to work OK, but I can not see anything like "libudf.*" in UDF source directory. The output is like this:
cl /c /Za /Dextern=__declspec(dllimport) -I\\molk\d\fluent.inc\fluent5.3\ntx86\2d -I\\molk\d\fluent.inc\fluent5.3\src -I\\molk\d\fluent.inc\fluent5.3\cortex\src -I\\molk\d\fluent.inc\fluent5.3\client\src -I\\molk\d\fluent.inc\fluent5.3\tgrid\src -I\\molk\d\fluent.inc\fluent5.3\multiport\src ..\..\src\chan_1.c
echo # Generating udf_names.c because of makefile chan_1.obj ………………………………………………………………………………………………
sed -n "s/^DEFINE_\([_A-Z]*\)( *\([_a-zA-Z0-9]*\).*)/\2\ /p" ..\..\src\chan_1.c >> udfdll.def
cl /c /Za -I\\molk\d\fluent.inc\fluent5.3\ntx86\2d -I\\molk\d\fluent.inc\fluent5.3\src -I\\molk\d\fluent.inc\fluent5.3\cortex\src -I\\molk\d\fluent.inc\fluent5.3\client\src -I\\molk\d\fluent.inc\fluent5.3\tgrid\src -I\\molk\d\fluent.inc\fluent5.3\multiport\src udf_names.c
echo # Linking libudf.dll because of makefile user_nt.udf udf_names.obj chan_1.obj
link /Libpath:\\molk\d\fluent.inc\fluent5.3\ntx86\2d /dll /debug /out:libudf.dll /def:udfdll.def udf_names.obj chan_1.obj fl5318s.lib
Any suggestions are very welcome. Thank you,
Dmitriy
Old   December 12, 2000, 03:41
Default Re: C++ Compiler for UDF
Lasse Rosendahl
Hi Dmitriy,
I use MS Visual C++ 4.0 - it seems to work fine (a little bit of dll confusion, but that can be easily worked around).
Lasse
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Fortran compiler Erik Siemens 2 November 28, 2008 21:05
Intel compiler for linux x86 marcus Siemens 1 November 9, 2006 17:43
Fluent 6.2 and gcc compiler in Sun Blade 2500 Nitu Gupta FLUENT 8 April 29, 2005 14:58
Fortran compiler Arnab Siemens 5 September 14, 2004 04:59
