Particle tracking
Old   November 1, 2000, 11:47
Default Particle tracking
Sugen Chetty
Hi guys
Just want to know what density is used when particle injections are used. Seems like the density of the primary fluid. Is it possible to specify a density without changing to two-phase ?
Cheers
Old   November 6, 2000, 07:25
Default Re: Particle tracking
Rüdiger Schwarze
You have to create a first injection. After this, You can change the particle density in the material properties panel. But don't forget to define the gravity vector when You want to describe the buoyancy.
Blood Damage Modelling via Particle Tracking in a Centrifugal Heart Pump scatman CFX 7 January 8, 2018 01:59
massless particle tracking problem Renold FLUENT 0 January 26, 2011 15:23
Particle Tracking for ion Jun CFX 2 August 31, 2010 09:19
Number density tracking rather than particle tracking Rebecca Main CFD Forum 2 April 23, 2009 13:52
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 02:29
