October 21, 2000, 03:57 |
hybrid mesh around a stator
Hallo.
I'm trying to generate a hybrid mesh on hub, tip and stator of an axial-flow low-speed compressor. I've created a triangular surface mesh using Ideas. I'm using TGrid V 3.1.0 to create the prisms in the boundary layer and fill in the rest of the domain with tetrahedra. The wall zones defining the boundary-domain are inlet, outlet an periodic. When generating the prisms TGrid projects the new created nodes to the periodic-zone. After triangulating the periodic-zone TGrid trys to regenerate the shadow-zone but exits. The error reported is: Regenerating shadow for zone side1-tri. 1987 triangular faces created in new zone side1-tri-shadow. Error: Mesh corrupted at c211533 merging bn3831 - bn3831. Error Object: #f I have no idea how to solve this problem. Can somebody help me? |
October 24, 2000, 16:41 |
Re: hybrid mesh around a stator
The problem is caused by unmatched faces on the periodic boundaries. Try to include the periodic boundaries when growing prizms.
October 25, 2000, 10:12 |
Thank you for answering.
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
[ICEM] Hybrid mesh for 2D boundary layer | Bigio | ANSYS Meshing & Geometry | 33 | November 18, 2019 10:15 |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 04:19 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 07:21 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
