Laminar vs. Turbulent Models
Old   October 18, 2000, 13:08
Default Laminar vs. Turbulent Models
Dahvid Brown
I am trying to model a 2-D rotating cylinder in a cross flow. The Reynolds number for my setup is 52,000 which should be in the laminar flow range. I have run both laminar and K-epsilon models in Fluent with mixed results. I get better results for the coefficient of lift with the laminar model, but my results for drag are closer with the turbulent model. If I could pick and choose from the 2 different models, then life would be great, but that approach isn't scientifically sound. My cylinder is 1 inch in radius and the free stream is 15 m/s. I am sure that my results are mesh independent. I appreciate if someone has some suggestions. Thanks.
Old   October 19, 2000, 04:49
Default Re: Laminar vs. Turbulent Models
Rüdiger Schwarze
The correct prediction of separation past the cylinder is essential in order to get correct results for the drag and You shouldn't get correct results for separation in the laminar flow field. On the other hand the lift needs a correct description of the laminar boundary layers, thus the laminar model will give better results for the lift coefficient.
Old   October 20, 2000, 16:23
Default Also Problem Converging for Laminar
Dahvid Brown
One more question on these models. Why is it that I have no trouble converging in the the turbulent model, but half of the time, I cannot converge with the laminar model. Thanks for your help.
Old   October 23, 2000, 03:36
Default Re: Also Problem Converging for Laminar
Rüdiger Schwarze
The laminar model is based on a wrong physics, therefore You shouldn't be surprised that Your iteration won't converge. More precisely You need the "turbulent" viscosity in order to describe the enhanced momentum transfer in the flow field.
Laminar flow or Turbulent flow mech FLUENT 0 January 27, 2007 19:51
modelling laminar and turbulent flow in the same Ol FLUENT 2 November 25, 2005 03:52
Laminar To Turbulent Swarup FLUENT 3 October 8, 2005 01:21
effective? turbulent? laminar? MissNancy Main CFD Forum 2 November 30, 2002 02:08
