A moving object within a chamber
Old   October 9, 2000, 03:51
Default A moving object within a chamber
Whitaker
Hi, everybody,
My problem can be described as: an object is driven to move within a chamber due to a flow passing through this chamber at some specific time. Apparently, this is a transient problem. It seems the sliding mesh won't work for this case because the sliding mesh approach requires the grid interface must to be situated such that there is no motion normal to it. The vertical dimension of this object is larger than the vertical dimensions of both the inlet and outlet of this chamber. So if I use the sliding mesh, the grid interface will inevitably cross the wall of the chamber.
Any suggestion will be highly appreciated!
Whitaker
Old   October 10, 2000, 04:01
Default Re: A moving object within a chamber
Pierluigi Allegro
Hi, I have a similar problem solving a rotor-stator with the rotor blade meshed. I'm waithing for an answer form fluent and i'll post that to you.
Pierluigi Allegro
Old   October 10, 2000, 08:22
Jin-Wook LEE
Dear Whitaker
As far as my experience is concerned, I've met fairly difficulaty situation for the convergence problem of energy equation for every simulation. It may be dependent of case by case. But I could obtain converged solution by adjusting under-relaxation parameter for energy equation for most case. I usually use underrelaxation parameter, 0.7-0.8, for start-up and increase step by step and eventually near 1.0. Then, it was O.K. for most cases.
I hope it will be helpful to you.
Sincerely, Jinwook
Old   October 10, 2000, 16:27
Whitaker
Dear Jinwook,
It seems this message was written for some people else. Anyway, thanks a lot.
Whitaker
Old   October 10, 2000, 16:32
Whitaker
Thanks for your reply. By the way, do you think it is a good idea to solve my problem using VOF? Just treat the solid object as another fluid with very large viscosity.
Whitaker
Old   October 10, 2000, 23:02
Jin-Wook LEE
Dear Whitaker
I am very sorry. It's reply for 'convergence....', another item.
Sincerely, Jinwook
[foam-extend.org] Error compiling OpenFOAM-1.6-ext Canesin OpenFOAM Installation 137 January 20, 2016 15:56
Truck brake chamber transient simulation - Moving boundary vatsa STAR-CCM+ 0 February 11, 2010 01:14
Truck brake chamber transient simulation - Moving boundary vatsa FLUENT 0 July 21, 2009 20:24
Compilation error OF1.5-dev on Suse10.3 darenyang OpenFOAM Installation 0 April 29, 2009 05:55
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
