Density as a function of height.
Old   September 26, 2000, 06:01
Default Density as a function of height.
Børge Kvingedal
Hello, I want to define a density profile as a function of height only. I do not want to use temperature in my simulation. Is this possible. I am planning to simulate waves over a mountain in a stratified ocean. Is is possible to define a profile in the materials panel?? Thanks for any help....
Regards Børge
Old   September 26, 2000, 07:35
Default Re: Density as a function of height.
Phil
I think you have to write a user defined function in c++. Than you have to compile it in Fluent!Some examples are given in the fluent manual. I don't think that this is possible to define in the materials panel. Only the temperature dependence can be defined in the material panel.
Regards Philipp
Old   September 26, 2000, 08:39
Børge Kvingedal
I have tried to write a UDF with the density varying whith height but I can not get it right. I have defined the velocity as a function of height, using UDF and that works well. I have now also defined the temperature at the inlet as function of height, but it does not work for density. Maybe I just have to use the temperature profile as a reference for the density although this is not what I wanted to do. This leads to unwanted convections....
can density be defined as function of pressure H.M.Tang FLUENT 7 July 7, 2019 01:53
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 01:35
UDF for density as a function of something not necessarily temperature! rmousavibt FLUENT 0 May 12, 2009 11:12
Solver and density function for high speed vapour christian OpenFOAM Running, Solving & CFD 17 April 12, 2007 03:41
User defined function for density gradient ben akih CFX 3 October 10, 2006 22:47
