particles in a localized magnetic field
Old   September 1, 2000, 16:45
Default particles in a localized magnetic field
Arturo Ortiz
Hi all. I am trying to simulate a system in which charged particles are moving in a fluid and there exists a weak localized magnetic surface source. Then the particles will be affected by a normal component of the magnetic force, some will be atracted as they get close to the magnetic surface(and will be traped) and others that are released far in the flow field, will just escape. The system is very close to the magnetic painting of surfaces. I will have to write a UDF to represent the phenomena, but I do not know how to obtain the particle-magnetic source distance as well as the normal to the surface. I've read the UDF manual and I was not able not find any answer. Any hint will be very appreciated. Thanks
Old   March 10, 2010, 11:26
niko_04 is on a distinguished road
i'm trying to do something similar. how do you do to get the particules to change its trayectory? I'm getting frustrated after all the tries and simulation I've done already!
niko_04 is offline   Reply With Quote
problems after decomposing for running alessio.nz OpenFOAM 7 March 5, 2021 05:49
External magnetic field data Richard Lee FLUENT 7 January 11, 2019 05:43
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Turbulence dampening due to magnetic field in LES and RAS eelcovv OpenFOAM 0 June 8, 2010 12:35
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
