blade shape
Old   August 16, 2000, 00:51
Default blade shape
sameer mohrir
Hello everybody
Can anyone tell me why shape (geometry) of axial compressor blades are more complex than Steam Turbine blades.
Sameer Mohrir
Old   August 16, 2000, 01:06
Default Re: blade shape
John C. Chien
(1). I don't think so. (2). The pressure increases along the compressor path, at the same time, the Mach number decreases. So, it is sensitive to flow separation. (3). For turbine blades, the Mach number increases and the pressure decreases. So, relatively speaking, it is less sensitive to the flow separation. (4). Internal flow separation and prediction is still a very difficult subject.
Old   August 16, 2000, 02:18
sameer mohrir
Hello John
Thanks for clarification
Sameer mohrir
Calculating lift force of a wind turbine blade problem LittleBart CFX 4 June 29, 2011 03:33
Meshing a 3D, tapered and twisted blade with Gambit-TGrid teskio ANSYS Meshing & Geometry 0 July 3, 2009 11:36
fan performance based on blade shape balaji Main CFD Forum 1 September 16, 2005 12:56
fan performance based on blade shape balaji Main CFD Forum 0 September 15, 2005 08:24
NACA blade shape L.Aouanouk Main CFD Forum 0 April 27, 2003 08:49
