Convection Terms in UDF
Old   August 12, 2000, 13:58
Default Convection Terms in UDF
Jon Thorpe
I am trying to set up a UDF to solve for a scalar.
I want to set the convective flux term to be V.A (i.e. the dot product of the Velocity and the Area).
The default options in Fluent 5.1 (on an SGI) are 'none' and 'mass-flow rate' for the convective fluxes.
I cannot see how I can write a UDF (interpreted is fine) the takes the dot product of the velocity field and the area vectors. I assume that it is simple (one line), but I cannot see how to do it......
Thanks
Jon
Old   August 14, 2000, 10:41
Default Re: Convection Terms in UDF
Rüdiger Schwarze
First You have to write and to compile the udf. When You open the udf library, You can use the udf as flux function!
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 07:05
parse error while interpreting udf Kristin Fluent UDF and Scheme Programming 3 March 15, 2012 07:43
I need UDF help. S.Whitney FLUENT 0 October 15, 2007 12:29
UDF - source terms Fred FLUENT 2 October 11, 2005 21:53
DEFINE_GEOM UDF Problems Pat FLUENT 0 August 14, 2003 14:16
