Compiling and linking UDS in FLUENT 4.5
Old   August 2, 2000, 22:09
Default Compiling and linking UDS in FLUENT 4.5
Raja Banerjee
Hi, I am trying to write some user defined subroutines (UDS) in FLUENT 4.5. The manual gives details on how to write and activate them but it does not say anything about compiling and linking the UDS to the remaining FLUENT code. I am using FLUENT on an windows-NT environment. I would appreciate if anybody can help me out. Thanks, Raja
Old   August 3, 2000, 01:07
Default Re: Compiling and linking UDS in FLUENT 4.5
Greg Perkins
If you look in the fluent4.5 folder there should be some files located in either the srcu or info sub-folders which tell explain how to compile on your machine (errata files are also stored here).
On our HP-UX Unix machine the file is uds_unix_flu45.ps and its located in fluent4.5/info. On NT the file will have a different name and may reside in a different sub-folder.
Regards
Greg
Problem with Compiling UDFs in Ansys Fluent 13 (lnx64) Ali.beh Fluent UDF and Scheme Programming 3 August 27, 2018 05:22
Please, Help with linking UDF precompiled outside fluent to fluent!!! gracerlima Fluent UDF and Scheme Programming 1 May 4, 2010 08:19
Fluent Remote Simulation Facility Service (RSF) di Rami FLUENT 2 June 4, 2008 06:38
Compiling error in Fluent eduardo FLUENT 0 December 18, 2007 12:46
CGNS libraries, compiling and linking... Ironman80 Main CFD Forum 2 February 14, 2006 23:36
