sequential batch run
Old   July 26, 2000, 13:09
Default sequential batch run
jy
I would like to run sequential batch run with fluent as:
fluent 2d -g -i 01.in > 01.out ; fluent 2d -g -i 02.in > 02.out ; fluent 2d -g -i 03.in > 03.out
but the command
fluent 2d -g -i 01.in > 01.out is equivalent to fluent 2d -g -i 01.in > 01.out & on my bourne shell, so it is simultaneous and not sequential, if only one licence is available: error message.
Any suggestions?
kind regards
jy
ps: 'echo toto' and 'echo toto &' aren't on my system, only the fluent command does that.
Old   August 2, 2000, 11:05
Default Re: sequential batch run
Chris
If you are on a unix system, the command you have should work. Make sure you don't have fluent aliased to something.
If you are on NT, use the -wait option on the command line to get the behavior you want.
Old   August 2, 2000, 12:41
jy
Thanks a lot! wunderbar!
jy
how to create input file to run fluent in batch Aireen FLUENT 6 November 21, 2016 09:27
to run a replayfile in batch mode from UNIX froztbear ANSYS Meshing & Geometry 4 May 13, 2014 09:00
batch run N.R. CFX 1 June 17, 2007 23:44
Batch Run Ogbeni CFX 4 October 15, 2003 13:33
Help!! Why I can't run fluent in batch mode? Cindy Jones FLUENT 0 April 9, 2003 00:39
