Gambit: Change the direction of the vector (edge)
Old   July 12, 2000, 05:37
Default Gambit: Change the direction of the vector (edge)
Phil
Is it posible to change the direction of the vector from an edge, because when I mesh the edge in an exponential way (hope that somebody understand what I mean!!), the generation of the nodes begins not at the "right" side of the edge.
Thanks Phil
Old   July 12, 2000, 06:09
Default Re: Gambit: Change the direction of the vector (ed
Rüdiger Schwarze
You may invert the mesh of single edges with the "invert" button!
Old   July 16, 2000, 23:37
Scott Gilmore
You can also shift-middle-click on the edge (during edge meshing) to reverse its sense.
[ICEM] Changing edge direction la7low ANSYS Meshing & Geometry 2 June 7, 2010 14:26
Gambit 2.3.16, Xming or Exceed...HELP! bambam3417 FLUENT 10 May 7, 2010 13:39
change of color of grid/mesh in gambit mvee FLUENT 3 April 23, 2010 12:17
Changing gambit file without change of case file?? Asghari FLUENT 2 August 28, 2006 14:48
no enthalpy change across the momentum source Atit Koonsrisuk CFX 2 December 19, 2005 03:33
