Runing the parallel version of Fluent in the background
Old   June 26, 2000, 07:09
Default Runing the parallel version of Fluent in the background
Carolin Kosiol
I've been running a Fluent job in the background with the following input file
rcd parallel_geo10.cas (iterate 100) wd parallel_100.dat (iterate 100) wd parallel_200.dat exit
and the command line
fluent 3d -p -t4 -g < run_parallel.jou > & log &
It worked fine but the processes did not finish and I had to kill them by hand. How do I change my input file, such that all processes finish properly?
Thanks, Carolin Kosiol
parallel fluent runs being killed at partitioing Ben Aga FLUENT 3 June 8, 2012 11:40
Saving *.cas and *.dat from parallel version Pfalcon ANSYS 1 August 15, 2009 09:18
Fluent parallel poovanna FLUENT 0 March 24, 2007 00:22
Parallel Fluent Usage ILia Skryabine FLUENT 1 January 19, 2007 09:31
FLUENT parallel run Sampath FLUENT 6 November 24, 2004 10:52
