compilation error
Old   June 14, 2000, 12:29
Default compilation error
M.A. Rakib
Why is the following UDF not being compiled as an interpreted UDF?
#include "udf.h" DEFINE_PROPERTY(cell_temperature,cell,thread) {
real temp = C_T(cell,thread);
face_t f;
real flow_time = RP_Get_Real("flow-time");
begin_f_loop (f,thread)
if (flow_time = 0)
temp = 300;
else
temp = 350;
return temp;
Error is:line 12: invalid expression for if : float
Old   June 14, 2000, 16:37
Default Re: compilation error
kostya
This error comes from unability to check equality between integer and real numbers. You could change the line
if (flow_time = 0) to if (flow_time < 1.0e-7)
and this line should be OK. I don't have much experience with UDF, but i'm not sure with what you are trying to achieve with this one. Temperature is not property, why dont't you use DEFINE_PROFILE or a field function?
Hope it helps
Old   June 15, 2000, 12:34
Chris
Note that the equality operator in C is ==.
You have an assignment (setting flow_time to zero), not an equality test.
Old   June 15, 2000, 12:35
M.A. Rakib
Dear kostya, thanks for the comments. But really I am still confused about the UDF to be used. Actually I want to define an energy source from time t=0 secs to time t=60 secs (i.e. 1 minute) at the constant value of say 5 W/m3. Then I want to stop the energy source ( at t > 60 secs), and find out the temperature profile as a function of temperature and time. Following is the crude form of the program, which of course has errors, as they appear on the console window.
#include "udf.h" DEFINE_SOURCE(energy_source,cell,thread,dS,eqn) {
real source;
source = 0.;
for (flow_time>=1.0e-7; flow_time<=60;
source = 5.0;
else
source = 0.;
dS[eqn] = 0.0;
return source;
The compilation errors that appear are as follows:
Error: source.cpp: line 10: parse error. Error: source.cpp: line 11: parse error. Error: source.cpp: line 17: parse error.
Here source.cpp is the relevant file.
Another question that I would like to ask is about the error. What is the meaning of parse error?
Old   June 21, 2000, 05:12
Matthew Brannock
I've just started to learn to program in C and use these UDF's also. I found a parse error just to mean a format error of some type (ie the use of brackets inside your 'if' loops, if you have more than 1 line after your 'if' and 'else' statements you need to put the '{' brackets in)
cheers,
Matthew.
Old   June 21, 2000, 11:28
Chris
A parse error indicates that the code is not syntactically valid C. You are going to need to learn C to do anything effective with UDFs. Here is a version of your code that sets source to 5 if flow-time is between (0,60] and 0 otherwise. I am not familiar with the DEFINE_SOURCE hook so I can't comment on whether it is doing something useful.
#include "udf.h"
real source;
if (flow_time > 0.0 && flow_time <= 60.)
source = 5.0;
else
source = 0.0;
dS[eqn] = 0.0;
return source;
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 12:39
OpenFOAM install on Ubuntu Natty 11.04 bkubicek OpenFOAM 13 May 26, 2011 06:48
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 18:38
user defined function cfduser CFX 0 April 29, 2006 11:58
