June 13, 2000, 08:24 |
Computation of Derivatives
Hello
I have obtained a solution using Fluent V5, but now I am trying to post-process my results. I want to compute and store the derivative of a variable such as total pressure (i.e. for a variable that is derived from the variables actually solved for). I can see that in the "Adaptation" section, there is an option that computes the derivatives of such a function, but it is not possible to store the result anywhere (I want to combine it with other things). It is important for me that Fluent does the computation, using it's own differencing. I know that I can take the data outside of Fluent, and write a small program to compute these things myself, but I want to see what the results are using Fluent's differencing. Does anyone have an idea about how I can get Fluent to compute the derivative of any derived varable, and allow me to store it inside Fluent? Any help would be much appreciated. |
June 15, 2000, 18:00 |
Re: Computation of Derivatives
One approach is to use a User Defined Function. Allocate 4 User Defined Scalars and turn off their solution. Then, in an ADJUST function, set the first UDS to the function that you want (eg pressure)...
C_UDSI(c,t,0) = C_P(c,t); Then, copy the gradient of C_UDSI(c,t,0) into the other 3 UDSs as C_UDSI(c,t,1) = C_UDSI_G(c,t,0)[0]; C_UDSI(c,t,2) = C_UDSI_G(c,t,0)[1]; C_UDSI(c,t,3) = C_UDSI_G(c,t,0)[2]; /* for 3D only */ Now you can plot the gradients. |
UDM derivatives for - for EHD flow | Sandilya Garimella | FLUENT | 7 | September 9, 2013 04:17 |
problem in the CFX12.1 parallel computation | BalanceChen | ANSYS | 2 | July 7, 2011 11:26 |
Discussion on the computation of the multi-stage axial compressor | BalanceChen | CFX | 5 | January 5, 2011 03:23 |
How Star-cd v3.22 do parallelling computation? | Williams | Siemens | 8 | July 16, 2007 15:21 |
Cell face values computation un unstructured grids | Sergio Rossi | Main CFD Forum | 2 | May 28, 2006 11:04 |
