surface tension model in EX26
Old   June 7, 2000, 11:49
Default surface tension model in EX26
Junhua Wu
Hi, I am trying to understand the EXAMPLE 26 coming with FIDAP(EX26nr.FDREAD).
The surface tension model is : SURFACETENSION(CURVE=2) -10.0 10.0 ($CAPINV +10) ($CAPINV - 10)
From the manuals, I think the first two data(-10.0 10.0) is temperature, the last two data is surface tension coefficient. Is it correct?
However,the boudary conditions are assigned using BCNODE: BCNODE(TEMPERATURE, CONSTANT = -0.5, ENTITY="coldwall") BCNODE(TEMPERATURE, CONSTANT = 0.5, ENTITY ="HOTWALL")
I donot know the '-0.5','0.5', I think it should be the value of temperature. What is the unit for them? How the surface tension model used in this example. Is it contradicting with the temperature in surface tension model?
I am learning FIDAP, any suggestion is appreicated.
Junhua
Continuum Surface Force Model Miguel Main CFD Forum 4 August 4, 2012 15:56
MULTIPHASE - FREE SURFACE & MIXTURE MODEL Aris FLUENT 3 April 28, 2009 12:46
two phase flow with surface tension qunwuhe@hotmail.com Main CFD Forum 2 October 21, 2007 01:29
Surface tension - Continuum Surface Force model Robert Main CFD Forum 0 May 2, 2002 08:34
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
