May 29, 2000, 13:23 |
Mass Flow Outlet
I am simulating a transient, compressible blowdown scenario with no inlet flows and a single outlet, where the mass flow rate is fixed via a PCV and a choked orifice plate.
Has anyone incorporated a mass flow OUTLET boundary condition into Fluent 5? One approach would be to adjust the set pressure in a pressure outlet b.c. via a UDF to meet the specified mass flow rate. Any other suggestions? |
May 29, 2000, 14:46 |
Re: Mass Flow Outlet
Hi! Glenn,
This scheme file ought to work (it was written for UNS, so it might not work for Fluent 5, but it's worth a try). Let me know if you're not successful. Graham Put the text below this line in a file mfo.scm ... ;;; mfo.scm ;;; Mass-flow outlet boundary condition prototype. ;;; Copyright 1996 Fluent Inc. ;;; All Rights Reserved. ;;; Usage: ;;; ;;; - Set up your case and data as usual, using a pressure outlet ;;; for the outflow boundary type. Set the outflow pressure ;;; to a reasonable value and, for best results, partially converge ;;; the solution before proceding to the next step. ;;; ;;; - Load this file by typing (load 'mfo) in the console window. ;;; You will be prompted for a few configuration parameters. ;;; You can examine or change these parameters at any time with ;;; the /define/bc/mass-flow-outlet command. If you want, you ;;; can change the default configuration values below by editing ;;; this file. ;;; ;;; - Then just iterate as usual. The outlet pressure will be ;;; updated once every n iterations to achieve the target mass flow. ;;; (define mfo/target-mf 10.0) ; target mass flow (define mfo/interval 5) ; update pressure every n'th iteration (define mfo/relax 1) ; relax pressure update (define mfo/min-pressure .1e5) ; limit pressure (define mfo/max-pressure 2.e5) (define mfo/verbose? #t) ; display status? ;;; end of user-configurable variables (define mfo/name) (define mfo/area) (define (mfo/ti-configure) (let ((po (get-threads-of-type 'pressure-outlet))) (if (null? po) (error "mass-flow-outlet: there are no pressure outlets defined")) (set! mfo/name (thread-name (car po))) (format "Using ~a.\n" mfo/name)) (set! mfo/target-mf ;; (read-real "Target mass-flow (kg/s)" mfo/target-mf) (read-with-units "Target mass-flow" mfo/target-mf 'mass-flow " ")) (set! mfo/interval (read-real "Iteration update interval" mfo/interval)) (set! mfo/verbose? (y-or-n? "Display update diagnostics?" mfo/verbose?)) (set! mfo/relax (read-real "Pressure change relaxation factor" mfo/relax)) (set! mfo/min-pressure ;; (read-real "Minimum allowable gauge pressure (pascal)" mfo/min-pressure) (read-with-units "Minimum allowable gauge pressure" mfo/min-pressure 'pressure " ")) (set! mfo/max-pressure ;; (read-real "Maximum allowable gauge pressure (pascal)" mfo/max-pressure) (read-with-units "Maximum allowable gauge pressure" mfo/max-pressure 'pressure " ")) ;; cache the surface area (set! mfo/area (surface-area (cx-get-surface-ids (list mfo/name)))) ) ;; add a /define/bc/mass-flow-outlet command (ti-menu-insert-item! bc-menu (make-menu-item "mass-flow-outlet" #t mfo/ti-configure "Configure the mass flow outlet")) ;; build a new profile boundary condition with a constant value (define (constant-profile constant) (list (cons 'constant constant) '("" ""))) ;; update the bc (define (mfo/update) (let* ((mfo (get-thread mfo/name)) (mf (- (cdr (assq 'mass-flow (thread-integrals (thread-id mfo)))))) (p (cdr (assq 'constant (send mfo get-var 'p)))) (rho) (dp) (new-p)) ;; compute the average density on the thread (client-set-node-values #f) (client-fill-node-values 'density) (set! rho (surface-average (cx-get-surface-ids (list mfo/name)))) ;; adjust pressure using Bernoulli's (set! dp (* mfo/relax (/ mfo/target-mf rho mfo/area mfo/area) (- mf mfo/target-mf))) ;; diagnostic message (if mfo/verbose? (format "mass-flow: actual = ~a, target = ~a, pressure change = ~a\n" mf mfo/target-mf dp)) (set! new-p (min mfo/max-pressure (max mfo/min-pressure (+ p dp)))) ;; update the boundary condition (send mfo set-var! 'p (constant-profile new-p)) ;; download to the solver (send mfo update-solver-vars!) )) ;; automatically update the bc each iteration (define (mass-flow-outlet-monitor niter . args) (if niter (if (zero? (remainder niter mfo/interval)) (mfo/update))) '()) (cancel-solution-monitor 'mass-flow-outlet-monitor) (register-solution-monitor 'mass-flow-outlet-monitor mass-flow-outlet-monitor) ;; check the configuration (mfo/ti-configure) ;;; end-of-file |
May 29, 2000, 16:06 |
Thanks alot Graham!
May 30, 2000, 12:23 |
Re: Mass Flow Outlet (Jonas, please read...)
Is there some way to disable the formatting of posts so that code can be posted legibly?
I have tried various html tags (pre, code, plaintext) but the indentation and line breaks are still being changed. Thanks, Chris |
May 30, 2000, 14:02 |
No, there is no way to do that currently, sorry. All posts are parsed in order to optimize the apperance of plain-text on different browsers. The parsing removes all line-breaks so that the browser wraps lines automatically based on window-width. Double line-breaks are translated into paragraph-breaks. This works okay on plain-text, which is the vast majority of all posts, but when people try to post tables, source-code, indendation etc. things will break. I know that it is annoying. I will try to find a solution.
Mass flow inlet and pressure outlet issue | nikhil | FLUENT | 5 | December 11, 2013 12:30 |
Mass flow rate at the outlet | tejasvikrishna | FLUENT | 2 | May 25, 2013 02:42 |
Species mass flow inlet | lorenz | FLUENT | 3 | March 15, 2012 07:26 |
reversed flow at velocity inlet / mass flow inlet | ib | FLUENT | 1 | March 26, 2007 13:11 |
Mass flow rate in outlet | Saturn | FLUENT | 1 | October 11, 2004 09:39 |
