rotation flow field simulation
Old   May 23, 2000, 20:57
Default rotation flow field simulation
wason
Hi, all,
I am using Fluent to simulate the rotation flow field in an vortex Pump(it is similar to an centrifugal pump)with a long outlet pipe. My question is, could I use single rotating frame method? if not, How to build a multiple rotating/ translating reference frames?
Best regards,
Wason
Old   May 26, 2000, 14:10
Default Re: rotation flow field simulation
LW
If you have only one pump, you should be able to define a single rotating reference frame. Make sure define a fluid volume in which the rotaing parts are enclosed. You also need to define the rotating parts (walls or solid) the same way. You will need to define rotaing axis and the center coordinates of the rotation correctly. Good luck!
velocity of massless particles and velocity of flow field in same coordinate payam_IUST FLUENT 0 October 19, 2009 00:24
potential flow vs. Euler flow curious ... Main CFD Forum 23 July 21, 2006 08:40
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 06:44
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
Flow field measurement in turbomachinery! Wanlai Lin Main CFD Forum 3 September 3, 1999 13:06
