May 12, 2000, 13:01 |
velocity inlet: sparger
Is there a usual way to set the velocity of a gas sparger in a fluid. I imagine that the gas will decrease from the velocity in to the sparger system to the limit velocity of a bubble in a fluid
vlim2=4Dg.(rhol-rhog).g/3Cdrhog But if you have a better way (with the pressure drop in the sparger system) you are welcome jy (www.pfd.ie) |
Unexpected difference between velocity / mass-flow inlet | jpo | FLUENT | 8 | December 10, 2010 07:20 |
[swak4Foam] Scale discrete inlet velocity profile with groovyBC | cboss | OpenFOAM Community Contributions | 1 | June 20, 2010 13:02 |
FSI- Pipe- uniform velocity profile inlet | Absy | Main CFD Forum | 0 | April 6, 2010 03:01 |
time varying inlet velocity | Zhe Liu | CFX | 0 | July 31, 2008 06:56 |
UDF problem : inlet velocity in cyl. coord. system | Jongdae Kim | FLUENT | 0 | June 15, 2004 11:21 |
