Cell Mass flux
Old   May 4, 2000, 17:32
Default Cell Mass flux
Sandeep Abhyankar
In a 2d problem with quad cells, I want to be able to calculate what is the mass flux of fluid flowing across a particular edge of the 2d cell. Is there a way to get this value by UDF's or by anything ?
Old   May 5, 2000, 05:11
Default Re: Cell Mass flux
Alfonso Ferrandez
Hi Sandeep,
the following UDF allows you to calculate the flux across any thread in a 2D domain. If you want to calculate it for a single edge of a 2D Cell, I would recommend creating it as an independent 1D INTERIOR boundary condition. Then you can apply the algorithm below. Perhaps a check for the nodal coordinates of the given cell would also allow for a modification of the function below (Jonas! Another one for the repository!
/************************************************** ****************/ /* This function calculates the flux across the given boundary. */
/* We make use of Fluent Macros for this. */
/* Note that the THREAD_ID parameter is the integer value shown as ID by the Boundary Conditions... Menu. */
/* Also, you must have defined domain as a global variable:
/* extern Domain *domain; */
real flow_rate(int thread_id)
real flowrate = 0.0;
face_t face;
Thread *face_thread;
face_thread = Lookup_Thread(domain,thread_id);
begin_f_loop(face, face_thread)
flowrate = flowrate + F_FLUX(face, face_thread);
end_f_loop(face, face_thread)
return flowrate;
Hope it helps! AL
Old   May 5, 2000, 09:51
Jonas Larsson
I've added this UDF to the temporary UDF library at:
ftp://ftp.cfd-online.com/fluent/
I named the file "flux_calculation.c"
As before anyone can contribute other UDF's by uploading them to:
ftp://ftp.cfd-online.com/incoming/
Old   May 5, 2000, 09:56
Sandeep Abhyankar
Thanks a lot AL.
mass flow boundary with fractional mass flux specifications ehsan_am86 CFX 2 May 19, 2011 04:02
flux around one specific cell solefire FLUENT 0 October 7, 2010 18:25
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 22:58
Creating 100 derived parts / Splitting derived parts for mass flux calculation xamo STAR-CCM+ 8 September 29, 2009 06:35
How are the mass flux and mass flow rate defined? Miles Siemens 2 November 7, 2002 09:45
