May 4, 2000, 08:02 |
Fluent 5.2, UDF and Pressure BC's
Dear all,
I've been working on a UDF for a loooong time now and there's something that's been baffling me ever since I started with it. Here's the details: 1) 2D Unsteady Incompressible 2) Pressure Inlet BC's (set with UDF and/or CONSTANT param) 3) Pressure Outlet BC's (set with UDF and/or CONSTANT param) Now, I need to determine/set the pressure on any of the 1D outlet boundaries, which I can do. Also I need to determine/set the pressure on any of a whole lot of 1D interior entities, of these I can calculate the pressure but I cannot figure out how to impose it across the entity. So, the problem(s): 1) I need to be able to IMPOSE a pressure value across any of my INTERIOR 1D threads. 2) When I calculate pressure across a 1D thread (with F_P()) I can obtain a "face averaged" value, but this is not accurate enough. in fact, if I "Report" on the pressure and choose "Facet Averaged" I get the same value as my UDF, but if I use "Vertex Averaged" I get the exact Pressure I expected (the value I need in my UDF). Sorry for the long post, but this is been driving me mad for a long time now and I know there's quite a few fine Fluent users here that might have the answer straight away. Thanks for your help! AL |
UDF to adjust pressure outlet | a.lynchy | FLUENT | 4 | February 15, 2021 01:50 |
Transient pressure UDF for parallel fluent | droberts | Fluent UDF and Scheme Programming | 5 | October 11, 2010 05:13 |
UDF to define or adjust pressure??? | engahmed | FLUENT | 0 | July 6, 2010 18:19 |
correct UDF code for unsteady pressure boundary | James W | FLUENT | 0 | November 2, 2005 12:38 |
UDF in Fluent to Match Mass Flow at Pressure Outlet | Jonas Larsson | Main CFD Forum | 1 | April 29, 1999 11:44 |
