X-Y plot of Yplus in Fluent 5.3
Like Tree4Likes
Old   March 30, 2000, 14:43
Default Re: X-Y plot of Yplus in Fluent 5.3
  #21
Jonas Larsson
You should check your eddy-viscosity field to see if it looks physical. On low-Re flows (some types of rotating cavities) we've had problems with discontinuities in the eddy-viscosity when using the Realizable k-epsilon - see my post below entitled "Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model" for further details.
Old   March 31, 2000, 08:52
  #22
Volker Pawlik
1. Your explanations were very helpful.
2. What I still find confusing is the use of u* in the Fluent User's Guide as s.th. different from u-tau. It is because, as far as I know, u* has already been introduced as a synonym for u-tau (i.e. the same, e.g Tennekes, A first course in Turbulence, p.53). Am I right?
Old   March 31, 2000, 10:32
  #23
Jonas Larsson
Tennekes & Lumley's definiton of u* is not the same as Fluent's (see Sung-Eun's post). Fluent's definition of u* does not involve the wall shear-stress - it is a pure turbulent velocity scale independent of wall-properties. Fluent calls T&L's u* for u_tau, the real name is "friction velocity". It's confusing, I agree.
Old   March 31, 2000, 16:08
  #24
Sung-Eun Kim
I'm afraid that I don't have a straightforward concise answer to your question. Please bear with me if things get too wordy.
The Wolfstein's one-equation is a wall-distance based, "near-wall", low-Re model, inasmuch as it is based on Re_y as turbulence parameter where y is the distance to the wall. It's a great, practical turbulence model that I've frequently seen beats up most of the contemporary two-equation low-Re models, in terms of accuracy, let alone robustnerss. But it would be least ideal to represent the low-Re effects, say, in a pocket of transitional flows far from the wall, where Re_y may be big enough (the model then reduces to a high-Re model) , but the flow is in reality transitional. In those regions, Re_t (k*k/epsilon), which is a more relevant turbulent Reynolds number, is not necessarily large enough.
If Re_y is smaller than 200 in most of your domain including the region where the mixing happens vigorously, it's not an ideal situation for the two-layer model either because you're then using effectively one-equation model that doesn't account for the transport of one of the important turbulent quantities (epsilon) in the flow where non-equilibrium effects are presumably significant.
So, If I am to follow the common wisdom alluded to above, I'll tend toward one of the low-Re models FLUENT offers underhand. But I have no hard evidence to support the recommendation.
Old   April 11, 2000, 07:07
  #25
Volker Pawlik
And what about the RNG-differential viscosity model which should form my point of view also address the problem?
How to plot the radius of a droplet's fall with Fluent baechtel FLUENT 1 May 1, 2009 05:51
How to plot Shear Stress Graph in Fluent? Jane FLUENT 0 November 19, 2008 21:30
How to plot pressure gradient in Fluent? jrg FLUENT 3 November 12, 2007 05:48
plot results of fluent cfd by tecplot sandra FLUENT 1 August 28, 2006 07:59
3d plot files to fluent 5 david smith FLUENT 0 October 26, 2000 18:54
