Boundary layer
Old   February 24, 2000, 08:50
Default Boundary layer
Park Geun Hong
Hi! everyone. I have some question in gambit Is boundary layer form(growth factor, depth....) affects greatly to solution? If it affects to solution, how can I make boundary layer on subsonic airfoil(depth=? growth factor=?....) Any rule is in it? Please response. thank you.
Old   February 24, 2000, 15:13
Default Re: Boundary layer
frederic felten
The boundary layer as the tendency to forget the initial conditions if you march far enough down the plate or the airfoil. So you can initialize your profil with some approximate value for the shape factor, for example, and it shouldn't change the solution after you march enough downstream of the airfoil!
[Gmsh] Default Faces on Boundary Layer axel OpenFOAM Meshing & Mesh Conversion 8 February 17, 2011 08:47
Boundary Layer Question scottneh STAR-CCM+ 3 September 30, 2010 15:21
Adapt mesh without modifying boundary layer cells? Freeman FLUENT 0 February 22, 2009 15:11
3D Boundary Layer Mario FLUENT 0 February 17, 2009 04:40
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
