VOF for flow around a ship hull
Old   February 24, 2000, 04:57
Default VOF for flow around a ship hull
Giovanni Ieria
Hello, I'm a graduate in Mechanical Engineering, I'm involve in a research about using Fluent in order to analyze the flow around a ship hull. I want to analyse the free surface with VOF. Can you tell me some suggestions?
Tanks in advance Giovanni
Old   March 6, 2000, 23:00
Default Re: VOF for flow around a ship hull
I. Jameel, Ph.D.
The VOF technique is nothing new. It was first proposed by the Hirt and colegues at Loa Almos National Labs. An early code that used this for free surface flows was SOLA-VOF. You could check the US Govt. publications to get a copy of this. and the code. since then this has been improved in code called Ripple also from Los Alamos. Dr. Hirt has now a commercial code FLOW-3D that uses this technique.
Basically a funftion Fij is defines where 0<Fij<1. This represents the volume of fluid in a cell. Based on the velocities this is fonvected across the cell. Fij=0 or 1 is a full cell and a fraction is a partial cell contining the free surface.
I have forgotten some of the other details as it has been about 8yrs since I did my Ph.D. using the SOLA-VOF code. I hope this is of help.
Cheers, MIJ
Flow around ship hull, multiphase setup!! alibul FLUENT 15 February 21, 2019 03:50
free surface flow arround a ship hull pavel915 FLUENT 0 April 1, 2009 02:55
Ship hull modeling on ANSYS CFX V11.0 jorllam CFX 0 August 1, 2007 13:43
Modelling flow around a ship's hull using vof Manoj Kumar FLUENT 0 February 26, 2005 17:22
VOF for ship Giovanni Ieria FLUENT 0 March 28, 2000 13:39
