Transient Simulations with FIDAP
Old   February 10, 2000, 13:34
Default Transient Simulations with FIDAP
Steve Aboagye
I am having a hard time with an aspect of the above subject. I am simulating a transient process that is memory intensive, and so I have decided to use a piecewise procedure, that is using a limited number of time steps per run and then continuing from the last time step for the subsequent runs until I attain steady state. FIPREP manual prescribes using the Restart mode of execution and then specifying the last time step and also specifying a restart data file which is the FDPOST of the previous run.
The problem is after all these, while I expect my simulation to continue from the last time step (say i=1000 then i+1 =1001 ) it restarts from i=1 and not i=1000 so it repeats what has already been done.
This fairly easy in FLUENT because FLUENT picks up from where it left off. (I have to use FIDAP and not FLUENT.)
Could a fellow out there help out if you know how do solve this?
Old   February 16, 2000, 13:59
Default Re: Transient Simulations with FIDAP
Eric Grald
Hi, Steve,
I'm going to email you a copy of the training notes file that covers this topic.
The key question is whether you are using the "execution restart" or the "read restart". There is a checklist for each of these items on pages 4-16 and 4-18, respectively, in the Powerpoint file I will send you.
If you're still having trouble, may I suggest that you access our tech support system directly (i.e., via your designated support engineer if you are an industrial user, or via jah@fluent.com if you are a university user).
Thanks,
Eric
Old   February 21, 2000, 11:55
Ahmed Hassaneen
Hi Eric, You always there to help FIDAP users. I think Steve is doing what I have done before. For him to solve this problem he should use (EXCUTION (RESTART)) instead of (EXCUTION(NEW JOB)) and READ command later. In this case, FIDAP will read from the last time step in the previous run automatically. If he wants to use (EXCUTION(NEW JOB)) and READ then he should specify the time step at which FIDAP will RESTART. Goodluck for you Steve and thanks Eric for your help to every FIDAP user. =Ahmed=
Transient simulations with translational periodic flow kriver FLUENT 11 April 18, 2012 06:56
Best practice for transient simulations? siw CFX 5 October 30, 2010 06:45
How are a transient simulations performed?? Luk Main CFD Forum 0 October 19, 2007 11:09
2D Transient flow using Fidap Young FLUENT 1 July 2, 2004 13:02
URANS and Transient Simulations bob Main CFD Forum 0 October 1, 2003 04:54
