Merging Meshes
Old   February 9, 2000, 23:43
Default Merging Meshes
Matteo Giacobello.
Hi, I would be very greatful if anyone has any suggestions on the following topic.
I have been trying to run fluent using using a merged mesh. I have tried merging two meshs using TGrid and the command line operation: tfilter tmerge3d mesh1.msh mesh2.msh mesh3.msh
The meshes I am trying to merge come together along one edge of a curved surface. One mesh consists of tetra elements. The other consists of tetra and prism elements. The result is that when the meshes are merged I have some tetra elements butting up to prism elements along the edge where the meshes come together.
Once the meshes are combined and read into fluent I specify an interface between the meshed. Fluent subsequently creates several new entities called 'wall- '. I have found that if there are zero elements in these entities fluent runs okay. However as soon as there are a few elemnts in these entities fluent complains that the pressure and viscosity limit have been exceeded in a few cells in the mesh and subsequently crashes. Based on these results I have come to the conclusion that I should always be aiming to have no cells in the 'wall-' entities.
When there are cells in these 'wall-' entities they always occur where the prisms butt-up againts the tetra elements.
In order to get rid of the cells in the 'wall-' entities I have tried varying the element size at the interface and recreating the interface.
Any suggestion on how I could get over this problem?
Thanks
Matteo Giacobello. AMRL-DSTO Australia
Old   February 16, 2000, 10:22
Default Re: Merging Meshes
Kai Kang
are you using the moving reference frame, like moving the mesh, during the computation?
the Wall- are generated automatically if the two interfaces are not conformed.
Those viscosity limits are just artificial limits, you can set it in Fluent/Control/Limits menu. It may have something to do with you IC/BCs.
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 07:41
[ICEM] Merging Hexa Meshes in ICEM screech1987 ANSYS Meshing & Geometry 11 March 13, 2014 12:45
[ICEM] Block/Hybrid strategy stuart23 ANSYS Meshing & Geometry 7 July 29, 2010 12:33
merging the meshes Virag CFX 2 March 5, 2007 07:41
Large 3D tetrahedral meshes Aldo Bonfiglioli Main CFD Forum 4 August 27, 1999 04:33
